I know that hardwood burners longer and hotter than softwood, but what is the ratio.
I can get a good supplier of softwood that can easily be processed but can't convert customers if I can't tell them if it works out cheaper.
:confused1::confused1::confused1:
Its a complete misnomer. Softwoods will usually burn hotter than hardwoods, and some longer. Its all down to the inherant calorific value of the timber, lists of which are available.
had a look at the fact sheet would suggest 1.6:1 ratio for (spruce,WR cedar, ppalr, willow): hardwood and 1.3:1 ratio for (Sweet chestnut, larch, D.Fir, pine, a;der) : hardwood.
So if follow similar price structure hen should be able to sell to customers.
Thanks for the info would never have found it on my own.
cheers!
Think time I went to pub
I think the reason why softwood has such a bad name is because of it's name (hardwood just sounds better than softwood) and because of all the problems associated with burning wet softwood....
I sell hardwood bags of logs for £60 and mixed bags (of soft and hard) for £55. Half of my customers go for the mixed wood. So no need to come too far down on price...
