Gidday Guys
I've been working (trying to place posts) in an area with a lot of heavy tree roots - its the sort of job I get quite often.  My Augertorque x2000 is just refusing to cut through them, it either "bounces" off and diverts, or stalls out.
Any ideas on how to solve this - am I using the wrong type of flight?  Not enough power? Is there a  specific tool??
Thanks
PS - for the job I'm on I've solved the problem ,just smashed them through with the Kinghitter's 340 kg hammer, but its messy and still tough going.
Augers will take the easiest path- and often the auger will just screw past a root if it can fit in the auger flight.
what tip have you got, I have the tungsten tipped flight on my x2500- rarely find it gets stuck on a root unless very large 4"plus- anything less it normally chews through.
only a 3 tonner behind it.
