Cheers folks
I'll mibee look into taking the beech down, althou it will be a pain with phone cables both sides pretty close by it.
I rally don't have any option of re routing them away from the trees just the way things are and where the sceptic tank is, I will stick ducts in for future just incase I ever need to stick another cable up
44 minutes ago, eggsarascal said:
I'm with Bob, leave the old services where they are and put new runs in.
if re-routing the power cables will be a problem sever them either side of the trees and 'patch in' a length of cable to rejoin using Resin joints.
err, thats a good idea.  I never would of thought of that, I'd be that set on a solution involving chopping down the tree's it would of gone right over my head to just chop em off ether end and start again..
Wot I use if I have to hand ball it is a pinch with a 4" brick bolster welded to the bottom.
When doing a lot of fencing it has been a godsend for getting posts in if u hit roots and need a post in that exact place.
And if u hit any stones u can just give it a buff with the grinder or a wee buff before tackling any seriously thick roots
Just recently I've had to dig some fairly hefty stumps/butts out and found an old axe with the chopping pinch is a pretty good combo
