Feed rollers just stoped today with no warning managed to finish the job by turning the ignition off and not turning the revs down witch keeps the machine running but no anti stress!! i think this just cut the power off to the anti stress unit.
On inspection the magnetic eye on the fly wheel is damaged but only slightly I'm hoping this is the problem whats your thoughts ?? Any help would be much appreciated.
Is there any troubleshooting top tips ??
The green and the orange light is on in the anti stress unit when you put the ignition on if this helps.
I have some pics on my phone if i can up load them i will??
Cheers men!!!:001_smile::biggrin:
Imnsure if the green lights on its getting the reading from pickup on flywheel?
Why has it been damaged? Bearings ok?
New magic eye sensor id start with.
There is a little brass knob that you can screw in on hyd block for feed rollers that over rides the stress if its same as a530
bearings solid the nut on the back of the pickup was only finger tight so i think thats why the end got took off its more damaged than the pic shows.
Do you know a ruff price for the sensor never had one go before??
Cheers again!!
