Dry oak boards
cornish chough
I have reclaimed 100 year old plus in those Thicknesses or I can mill to spec... Problem is that I am in Croatia so unless you needed a couple of cubic metres or more is isn't really viable with transport costs.
Braces are 1.6m x65mm x125mm reasonable curve approx120mm deflection if that makes sense
Thanks
They will definitely be sized for 125mm width as they were collected for boat frames and that's the right size. Length will be the issue as nothing is that big on the boat.
Deflection makes sense.
I will have a look in the morning and see what is in the pile - how many do you need?
Alec
