2101xp cylinder head conversion.
Would any of the Wizards here be able to advise on possible cylinders that might fit this saw. I don't need one right now, but knowing my luck I will sometime in the future.
The OEM cylinders are seemingly rare as hens teeth.
I was wondering wether a 395xp cylinder would work but I've noticed it has the same bore, but a 2mm shorter stroke.
Any thoughts would be much appreciated.
Just use top quality oil ( Husqvarna XP or Red Line etc ) Make sure the carb is always adjusted correctly and it wont over rev . Keep all the potential air leeks at bay and it should keep going for a good while yet .
