Hope someone can give me some advice on this.
I recently bought a Oregon chain for a saw, this is the one I bought: [ame=https://www.amazon.co.uk/gp/product/B00665KPX0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1]Oregon 73LPX068E Chain, 3/8-inch Pitch, 68 Drive Links: Amazon.co.uk: DIY & Tools[/ame]
The chain fits the bar fine as that is the type of chain stamped on the bar, this is the one I have: [ame=https://www.amazon.co.uk/dp/B0029ZQDZ0/ref=pe_385721_51767431_TE_dp_2]Makita 415045655 45 cm/18-Inch Sprocket Nose Bar - Multi-Colour: Amazon.co.uk: DIY & Tools[/ame]
However I don't think the sprocket on the saw is correct for the chain, its a 325-7T similar to this: OREGON PRO CHAINSAW SPROCKET DRIVE RIM 11892 .325 7 TOOTH | eBay
I'm not even sure what i'm looking for even exists however the chain seems to grind on the sprocket a lot. Can anyone tell me if there is a different type of sprocket available to suit this setup?
Thanks in advance.... :blushing:
I recently bought a Oregon chain for a saw, this is the one I bought: Oregon 73LPX068E Chain, 3/8-inch Pitch, 68 Drive Links: Amazon.co.uk: DIY & Tools
The chain fits the bar fine as that is the type of chain stamped on the bar, this is the one I have: Makita 415045655 45 cm/18-Inch Sprocket Nose Bar - Multi-Colour: Amazon.co.uk: DIY & Tools
You are running a 5/16 pitch sprocket with a 3/8 pitch chain,so change one or the other. You might have a problem finding a sprocket to suit that saw however.
