  • Replies 54
Hi mate, I've backed it off as far as I'm comfortable with and get the same result. That is to the point that when I pull the chain away from the bottom of the bar I can just see the bottom of a drive link.
Sent from my SM-G930F using Arbtalk mobile app
Back off a bit more, you don't need to run it like that but let's see what happens, you might just have a chain with excessive tight spot ?
On another subject i had a cheap pole saw that was going tight and clicking, turned out 3 or 4 of the drive links were burred over at the edges. Was an Oregon chain, 90 % good links, and almost new. Needle file, burrs removed and all good....well, as good as it was going to be.
bmp01
bmp01
I thought that but he says it does it on a 15" and an 18" so 2 chains and 2 bars makes me think its maybe the spur .
Doh :blushing::lol: , I missed that. Thanks for highlighting it.
2 excessively tight spot chains then :lol:
Actually, lets see what the result of loosening the chain is.
Also, If the chain tightens every 7 drive links (one rev of the sprocket) then sprocket is at fault.
bmp01
Doh :blushing:[emoji38] , I missed that. Thanks for highlighting it.
2 excessively tight spot chains then [emoji38]
bmp01
Thanks guys. I'll loosen the chain off tonight and let you know how it is.
Doesn't seem to be related to a position of the sprocket. Seems like you have to use more pressure to start it moving but after that it rotates more freely.
I'll also get a new sprocket on order.
Thanks
Toby
Edited by Toby in Buckinghamshire
More detail
Peatff how would I test that? Surely the clutch doesn't engage unless the engine is running?
The sprocket spins freely when there is no chain and bar attached.
If the clutch drum is a bit oval or your clutch bearing is dodgy it will catch. If it spins freely no problem.
