i have had quotes for ground protection from eve trackway http://www.evetrakway.co.uk/ for getting mini diggers over lawns its pricey (local NT estate have a length about 10m worth and its very good) evetrakway also do all glastonbury site matting!
we ended up using ply (due to budget restrictions) renting an access track was about 6x more than the ply for a 30m length for two weeks!
the 3/4" ply seemed to handle 6tonne diggers, unimogs and tractors passing over it relatively well we had one sheet that had cracked at the end of 2weeks use!
Sara ramps are far to expensive i got a 7 ton capacity set sent over from germany for £620
heres there number00496543502503, if you are needing some quickly a friend of mine has a 3m long set he is selling for £500. just outside cambridge
if interested give me a call steve 07889 511260
