i think i will do it. i can get them flat pack for £0.70 a box. does this seam expensive to you guys. the size is 300mm x 300mm x 300mm
That seems expensive to me. I buy 1000's of boxes every year.
For "off the shelf" boxes Kite Packaging are decent:
https://www.kitepackaging.co.uk/scp/heavy-duty-cardboard-boxes/double-wall-boxes/
If you look at the 6th option down you will see your size.
If you want bespoke / printed boxes, I can not recommend connect packaging enough.
I worked in a box factory and if you have one anywhere nearby ask if they have any rejects about the size you need. We used to make plain boxes for firms to sell on and 70p does sound a touch expensive unless you are buying them in 10s or less.
