But, but....
So 20 thou, 0.5 mm - how much extra life is that going to get you?
Compare it with a new bar, how much metal have you got before you run out of clearance, got to be 2-3 mm minimum??
In economic terms you've got;
Cost for bar rework to get you 0.5 mm life verse Cost of new bar with 2mm life...so in component costs alone the rework has to cost 1/4 of a new bar.
Cant see that happening.
bmp01
I have not measured a bar so it's all a bit finger in the air, should know better really, the machine can grind whatever it's just a case of working out what's acceptable
  • 1 month later...
If chain is bottoming out, I run a 1.5 mm slitting disc down between guide rails before pinching them in
Then put spirit level across rails and square them up
I've been doing this for processor for a few years using old bars up
i thought a worn bar was mainly the groove becoming to wide for the drive links to fit snuggly?? how can you referb that?
carl
