I've a 357 and a 346. Both have had issues with the sop button not working. Firstly they became temperamental now have stopped altogether. I've checked the wire and spade connector to the switch and all seems to be were it should be.
Any ideas?
Many thanks
Brett
Just get a multi meter, put it on the "Ohm" range or "Diode test" buzzer and measure that the switch is conducting when actuated. sometimes a little crud gets in just above the female spade connector. If the switch is working, it may be a damaged wire but the wire is usually very reliable.
