Can someone please help me by explaining why i have this damage to the tip of my bar sugi 12 ins running on a echo cs 281 1/4 pitch chain. i have been carving with it all week, sharpening as required, came to do some maintenance and cleaning etc today and spotted the damage to both the bar top and below the tip aswell as chain links on the underside.
Has the chain been running toooo slack or is it something else. I thought i looked after my equipment until i saw this :blushing:
Any help would be appreciated (rob d :001_smile:) i have been watching Simons video on bar maintenance and i think its becoming clear now.
I've done a couple of bars the same Ian, and I think it's down to the chain being too slack allowing it to slap as it goes around the tip. It seems to burr the links as well, which accelerates the damage. Some of it can be removed by dressing the bar, preferably with a diamond stone, as files won't touch the stellite tip.
I've got a small block of wood with a groove routered in it to take the diamond stone, which keeps it square to the bar. I'll post a pic tomorrow if I remember.
This kind of thing
Edited by Ukulian
As mentioned above could be chain is too slack, something I often do too.
Can't see properly on my phone but looks like the chain has some rollover on its underside. Have you got a power file? I dress the tip with powerfile as the normal method with a file won't touch the steatite edge.
Once you've sorted the bar just put a new loop on.
Are you filing the cutter heals ?
This kind of thing
Thanks for the information Ian, i will have a go at dressing the bar and get a new loop of chain and see what happens. i have a diamond stone now from a friend of mine. :001_smile:
I don't have a power file Si, I have a diamond stone I will try tomorrow and see if I can put the bar right. I have a fresh chain to go on then and yes I do file the heels by a couple of mm.
Thanks for the help Si
