Remote generator starting.
Daniël Bos
Heeeelp!
I want to remote start a diesel generator.
I have a generator that provides mains voltage and battery bank charging.
I have a battery monitor with an adjustable relay output that can close the relay when battery voltage gets below a preset threshold and opens again when voltage has risen sufficiently (to a preset level so as to avoid the genny coming on often in short bursts)
The signal from the monitor can only power a relay.
How do I convert the simple "relay on" to "ignition on, 10 seconds of preheat, 5 seconds of starter"?
And then back to all off when the relay contacts open again?
Confused...
Daniel
