yep thats correct i got mine in mid 2013 its a derated 372 xp , all you need to do is take off the side transfers , grind out the restrictors and you have a 372 xp /xt , i did that to mine and the difference is not huge but does respond faster and cuts faster , the differnce is the cost , quite a lot , but all the parts are the same , same saw , just de rated for homeowners
got a 3013 365 x torq there 70.7cc exactly makes 3.6kw of power and revs out to 10200rpm the 372xp is 71cc and makes 4.1kw of power the the same for but the like for like but the 365 is restricted by transfer ports and a baffle load of how to vid on youtube. there is about 230 pound difference in price between the saws huksy own website say the 365 x torq will run maximum or 28 inch bar. mine lives on a 18 inch and have used a 24 inch fine from time to time
