You will have to take the cable, and cable drum off first, before you drive out the center shaft. I resorted to using an aluminum headed fencing mell to drive out the center shaft You might need a clutch puller to remove the winch activating arm between the nuts and the drum.
If the winch has not been used for a while, the bearing will probably be seized, and can be a pig to get off as well.
Enjoy. :lol:
If you e-mail fransgard with the model number, they will email a parts diagram which will help.
So I attach the cable to a tree and drive away. Then how does the cable drum come off.
Thanks
John
Sent from my GT-I9505 using Arbtalk mobile app
The drum should just pull out by hand, unless the bearings have seized. One of my drums just pulled off, the other i had to resort to a tirfor winch to pull it off. Heat will help if it is stuck.
I did one the other day I'm pretty sure it just knocked out but definitely the cable stayed on ... you had to remove the cage around the spool though to get it out.
To be honest just take it apart ... hit some bits with a copper mallet and use a prize bar they are very easy to work on .. the worse bit I found was remembering where the engage handle was to properly Aline it with the 3 pins but it's all in slacks photo.
  • 3 weeks later...
John ,I took the front plate off and belted it with a copper mallet, took some force to get it move! .. I don't see why your puller/pusher should not work though.
