Evening I've a problem with my 190 it tracks forward ok but when you track it back it pulls to one side and eventually the right track will stop
Help
have a look at the adjustment on the linkage if it has any for a start I presume it doesn't have pilot controls make sure that the spools are getting full stroke both ways
As said, check that the levers are okay, check that the spool is getting travel too. Worth checking oil level of n hubs as low oil or bad oil ain't good!
Also worth jacking the dodgy side up , slacken the track and check the tensioner assy and idler rollers are all free to turn..
All right you clever shite, I missed that!
