I have a timberwolf 150dhb 2007, and the stress control isn't working properly.
basically its not kiciking in until to late causing it to stall the machine sometimes
Does anyone have any answers?
Thanks in advance
Edited by Ilovearb
Without checking up i think the Speed sensor takes the Alternator speed to judge when to kick in the No stress mines a 2009 and did the same was kicking in slow but adjusted the Alternater belt to the corrct tension and Kicks on on time everytime also check tension of drive belts as ever little will help
if you have a seperate sensor on the flywheel etc then clean and adjust gap on that also it will be either alternater pick up or flywheel sensor
Edited by Benny4817
spelling
