hook of the tubes, of the underwater cylinders
[ATTACH]218387[/ATTACH]
Hi Giorgio, thanks for sharing this, we have had a play with this set up as I really like the idea of knot blocking with a cambium saver as it makes retrieval easier.
The plastic clip, really helps to stop the slack getting into the system as I have found on some climbs without it!
  • Replies 60
:thumbup:
I could never see logic in the Quickie design.
What is it a solution for?
Anchors, long term anchors that are out of sight, need to be rigged counter to what the Quickie offers.
I wonder how much force it would take to smash those pin heads off when cross loaded?
That is a good point Wooden Hand re. the Singing Tree Quickie.
Handy though it doubtless is, it looks as though there's little 'redundancy' in this application.
I would think back-to-back screw gate crabs would be of at least equal, if not greater robustness ?
Carabiners have poor off axis strength, a mallion is probably a better choice
Just got a delta mallion to use for top tie.
Did you get one with a captive bar? Will you carry a spanner to tighten it?
Sent from my SM-A300FU using Tapatalk
They can be tightened with another maillon of the appropriate size.
