Stihl bg85 coil or carb problem?
daveindales
Ok, my 15 year old blower suddenly stopped today. Thought it was out of petrol, and it was. However, it suddenly stopped, not coughed and spluttered a bit before stopping, like things usually do. just stopped.
Filled her up with juice and she won't start. Plenty of compression, I don't think it's a piston problem. Taken carb apart and cleaned with carb cleaner. All looked ok. Plenty of fuel in primer build, so fuel is getting to carb.
Have put a bit of petrol down cylinder and she makes an attempt to fire, but won't start. So it seems to me that petrol isn't getting to cylinder. I checked the spark with a couple of plugs, (grounding on cylinder) and I thought the spark seemed very weak with both plugs. Gap to coil seems ok.
Anyone any ideas?
Just seems suspicious that the issue has started after running out of fuel to think the coil could be at fault?
I would think carefully before getting dragged into spending money on a 15 year old blower trying to get it sorted, maybe its time to treat yourself?
I would guess on the carb but engine could be tired also, has it good compression?
