550 muffler mod
TheHungrySquirrel
I have figured out the how and where to modify but need a way to reseal the deflector after bending it up.
Am I being silly in thinking I can solder it the same as I do gas and pipe fittings??
Better off welding or at a pinch brazing . Solder would probably soften from the exhaust heat . My 560 exhaust can was cut and shut with weld .
Thanks for that, I can't do either as my welder a broken and so is my torch 😒
Ended up lifting the deflector and poking the drill in there like a mad man.
