Is it advisable to prune (20%) foliage removal on crown lift a grafted cherry (dbh 80cm) infected with honey fungus?
Are you 100% certain its Armillaria mellea and not one of the other more benign Armillaria species?
I've left the tree with honey fungus as I expected that advice. Subsequently found a slightly larger cherry, same site, with sulphur tuft growing at the base. Again the ID is correct. As I understand this fungi is saprophytic so will it a) affect the tree (theoretically no) and b) shall I prune (approximately 10-15% branch removal on a crown lift)?
