Heya all, sorry for the boring question... Do pick up tubs vary in size between the 2wd and 4wd models?
More specifically the ford ranger 2wd & 4wd, mk1 or 2
Can't find any info on t net, the reason I ask is because I'm hoping to pick up a truckman top in the next couple of days - off of a single cab 2wd b2500
Thanks!
Thanks!
Hello Max, I is fairly sure they are the same atween 2wd and 4wd.
They are the same tibs for sure on rangers
Is it definitely a truckman brand if you know the model someone might have the same that can tell u about the ladder rack my old ranger with the base model truckman retained its ladder rack as did my new one with an aero branded canopy
