  • 3 weeks later...
[ATTACH]213426[/ATTACH]
We used most of the timber repairing this building. It was a game larder for the estate and still has all the hooks for hanging the birds and deer.
Sent from my GT-I9505 using Arbtalk mobile app
Looks good John, did you taper the feather edge?
No, in the end we did not cut featheredge.
I did make up an attachment for the Lucas copying* pictures of an original.
It worked but there were 3 problems. Firstly* i was not clever enough to work out how far to move the blade across after each cut. It was no longer a simple matter of* using the scale.
The blade cut too deep on the vertical cuts causing saw marks on the uncut log.
The third problem was that a small deviation of the blade that would not be too noticeable on an ordinary board would show up badly on a featheredge board. Once the trim to cover the end grain is on* one can not tell.
I am going to make an attachment for the Mizer which I am thinking about bringing back from Wales to mill in our friend Jeremy's wood.
John
John
thanks john, good to see your busy as usual, I really must set up my feather edge attachment for my mill, your always welcome to borrow it:thumbup:
