Hi all
I'm after about 140m (I think, in two runs) of stock fencing, near Chepstow. Fairly easy ground (one run up a gentle ish slope, other run fairly flat across the slope), pasture land, no existing fence to rip out. Access for (small) tractor should be fine. I'd like sweet chestnut or something else what will last equally well. Rabbit netting will be needed I think, and possibly a single strand of barbed on top (TBC - neighbour occasionally puts horses in the paddock next door, so may be a bad idea).
Can anyone give me a rough idea of likely price for this, and can anyone recommend someone in the area who can do this? Or does anyone on here do fencing in the area?
Many thanks.
(Posted this twice as I'm not sure where more people will see it)
Is it a field or garden?
Is the rabbit netting necessary, that will increase the price as the labour is quite a bit more.
Price wise, between £4-£5 pm if you can get someone local in. (That's standard stock fence using sweet chestnut, not inc. rabbit netting)
It's the edge of a paddock, with woodland and garden on the other two sides. I want to plant trees, so I think rabbit fencing will be necessary? Not moved in yet, so not sure what's about. When you say standard stock fence, you mean wooden posts and wire netting, but the netting not dug in? (That's what I think of as rabbit netting, but maybe I've got the term wrong?)
Thank you.
I'm up the road from chepstow and use a local fencer, had him in to do my sisters alpaca paddock on a very steep slope. If it's post and rylock (stock fencing) with two barbed on top expect about £6 per metre. Id put
any rabbit netting behind the rylock to stop them pushing their way through it.
Edited by timberbear
