550xp high idle problem
Thebigm
I've checked the spark plug and that's fine - colour wise.
I'm assuming they checked the throttle with the diagnostics, however it does click the choke back when the saw isn't running if you get what I mean.
They told me the carb would need replacing, but it doesn't seem worth replacing in the long run.
I'll take it back into the shop again on Tuesday to see if they can find an air leak, and as for warranty I rang the place I got it from and it ran out just under 2 month ago, so it would be a possible good will gesture from husqvarna which I can't see happening. It's a shame as I've just put a new bar and chain on!
