What do you guys use to finish your carvings, benches etc with? I've used a random orbital sander on coasters, and briefly, a grinder with sanding pads. Both did the job well but I now need to buy one or the other.
Just wondering what the popular choice is for the more experienced of you?
Sanding is where most of the work is IMO. I now use angle grinders to get the saw marks out of wood (with a range of different grits) and finish with a makita orbital sander.
Have used belt sanders in the past but found them to be too slow...
If its for indoor woodwork then I give it a coat of sanding sealer and then wax it
Does this sanding sealer reduce the sanding required on your pieces? (he asks hopefully)
Edited by Craig F-J
Yes, having used both a grinder and an orbital I can see that 1 would work well with the other. Hoped that there may have been a way of avoiding buying both. I'm hand sanding Yew coasters at the minute, what a workout!
