  • 0
Is this squirrel damage?
Plwm
Question
Hi there, I noticed some of the top branches of one of my trees were dead. When I went to have a look at the tree close up I found quite alot of bark stripped off as per the photos, and as you can see in one pic there are alot of strips of bark on the ground around the base.
Have squirrels done this and if so what are they after?
5 answers to this question
  • 0
I was just out looking at similar on a beech tonight. Definately squirrel I would say. The one I saw has deer fencing, so it wasn't a deer.
Just because it is deer fenced does not automatically mean there will be no deer in it. Will vary from site to site
Seen some big deer crawl throu tiny spaces that u would not think was possible.
Once watched a moster sika stag with a craking set of antlers get under a deer fence throu a tiny hole and it was a big deer.
The lower ones could be deer or even sheep/hares/rabbits but if it looks the same as the higher stuff chances are it will be squirrels or it could even be 2 different animals
Deer tend to rip as only 1 set of teeth, whereas most other animals that strip bark will ahve clean cuts,
