I have a Dosko grinder fitted with an 18hp Kohler and a centrifugal clutch. Even at very low revs the wheel is spinning slowly but on occasion it will slow to a stop.
I need the engine running to power the drive but its dangerous doing so with the head is spinning :001_rolleyes:
I took the clutch apart and all seems fine, as i say it does work correctly on the odd time i start it.
Any suggestions?
get in contact with kim at danequip very knowledgeable or with put you through to the workshop even if you have no intention of buying so much help i have had of them with my dosko chipper on getting me parts and running me through stuff so sort a fault
Thanks, ill give them a call.
To be honest Im thinking it would be a better idea to switch to an electric clutch, not sure what will cost or entail.
Edited by Suffolk-Matt
Thanks, ill giev them a call.
ask them as there grinders are a relabeled dosko unit as danequip use to be dosko dealers for chipper and grinders
