Idiot used pipe cleaners as a piston stop
EairthTree
Nah, think I will give it a miss as most use piston stops or rope and gather they work OK:001_rolleyes:
I would take the top end to get rid of all the debris, the steel bits would cause havoc with the bore and go very carefully refitting the rubber boot, I usually fit the rubber part and then the plastic support and clamp - it saves misaligning the impulse nipple.
I can't tell if this is a joke or not :). Impulse nipples and rubber boots?
You need to get the cylinder off and clean the crankcase /fly wheel area out, the debris can get there through the transfer ports.
Ensure there is no wire in there or the ports, or it will likely wreck things on start up.
Ok, so I took the cylinder out, under that was I circular disc mounted on the ?.. Flywheel? On top of the disc was a nice green bit of fluff, score. Within the flywheel, upon turning it I see nothing down there.. But then my view is obstructed by it obviously..
Is it possible I've rectified my ingenious usage of pipe cleaners? [emoji1374]
Well done, you will be learning from this.
What I'm concerned about.. Well one yes, that the rebuild will be sound [emoji269][emoji16], but firstly the scoring on the piston, that I assume was made by the wire, it's left small grooves... I rubbed them, to break off any teeny filings. No serious damage though right?
Also I didn't lubricate the piston before setting it back in place (without a special tool). Ach I'm such a worried noob!
