Interesting Hitch climber variation
Steve Bullman
  • Replies 20
After 2 attempts with this setup I am of the opinion that a prussic loop is the way to go. While the Ropeman may slide up easier the fact that the Ropeman wants to advance while taking up slack takes all the advantage out of using the Ropeman. The prussic locks in both directions making this much more user friendly. The prussic also seems to make going back to the normal system easier also!
Changing TIP's is easy as long as you remember to clip the 'biner that the spliced end is attach to...........to the ring on the bridge.
