The original post says 8kg at 32% moisture therefore just under 1/3 is water. If this is the case and you dried it completely then you would have 5.44kg of wood left at 0% moisture. The add your 11% of 5.44kg and you get 6.03kg.
Still not quit but nearly. the answer is 6.11 kgs.
You are correct except you dont add 11% of 5.44, instead you work it so that 5.44 is 89%, its that difference that was confusing us, you got the first bit right.
68% of 8kgs is 5.44 and if 5.44 is 89% of the finish then it weighs 6.11kgs
  • Replies 56
You can have wood with 200 % moisture content
Depends on definition - you could have wood with 200% added moisture vs dry weight but it doesn't make sense as you are not adding anything you are removing the moisture by drying. 100% is the starting point not the end point therefore when you cut the wood it is 100%, this reduces as you dry it.
Also selling wood calculated the second way gives a lower %moisture figure which looks better.
Depends on definition - you could have wood with 200% added moisture vs dry weight but it doesn't make sense as you are not adding anything you are removing the moisture by drying. .
Thats how the moisture content of wood is calculated
150% moisture content is 150% weight of the dried wood.
So Balsa wood can have a huge moisture percentage
If thats the case then Rupes calculation wouldn't work.
If your wood is originally 200% moisture how does Rupes calculation (100% - %moisture@ start = initial multiplier) work?
8kgs started off being 68% wood and ended up being 89% wood.
As above
I see where you are coming from but if the original said 8kg @ 200% what does the calc look like?
200% states there is 2x as much water as wood therefore it is 8kg x 0.33 or 100/(100+200).
Does this mean that in the original example it should be 8kg x 100/(100+32) = 6.06kg dry
6.06 x (100+11) / 100 = 6.72kg @ 11%
