Vermeer BC190XL
Vermeer UK are pleased to announce our new BC190XL chipper
The New BC190XL, is a new chipper from the ground up, aimed at the utility and contractor market, where strength and build quality are essential requirements. A Vermeer machine is built to be tough and rugged from day 1.
Outstanding performance
The BC190XL has an exceptionally large class leading in feed (200mm by 300mm). With very large off set rollers, the BC190XL is easy to feed, whether you are feeding very small material to large awkward branches.
Couple that to a heavy weight disc, and the horse power to drive it as well. 48 HP T4 Kubota engine. With Vermeer Intelligent Smart Feed, helps keep productivity high on this machine.
Operation and serviceability is a major design feature
With a simple push button start and automatic banded belt tensioner, life is easy from day one. Large accessible doors to the service area. Remote greasing of the large oversized bearings. 4 double sided blades, which are easy to change.
The BC190XL is tough and rugged with unparalleled performance. But weighing in at just 1.450kg. The BC190XL is built to perform and work, combined with a 3 year warranty and Vermeer backup - you can have peace of mind with your new investment.
  • 4 weeks later...
  • 3 months later...
  • 7 months later...
