Stihl hs81
laustin956
Is it just slight seepage? Did you replace the needle and metering arm?
If you are getting slight seepage then you can use a light smear of oil on the gaskets and do the covers up tighter. It generally helps.
Very slight leaks tend to seal once fuel gets in to gaskets and very rarely give issues - that is if they are slow leaks!
