3120 in for repair after being used for milling hard for a couple of years.it needs spark plug insert that's almost sorted.
The problem is the exhaust the old one is almost a jigsaw.
It is non standard exhaust no long bolts just two short bolts.
Bolting it straight on two cylinder.
And no part numbers.
Note, new part has 4 holes in,mine has 6
You are talking about the mounting bracket rather than the exhaust can itself ? I have a brand new exhaust can if you need it .
