Hey folks I was in the process of swapping out the points on a couple of 028av's and damages the flywheel on the donor saw in the process, don't need it anyway says I until I noticed a difference in the two wheels. On one wheel (the damaged one) there is a clear flat point on the back where it slides over the tapered crank, I assume this flat section opens and closes the points as it rotates, acting like a lug on a cam. But on the other wheel the same part is perfectly round. The points had already been robbed from that saw so I don't know if they open and close off another part of the flywheel. Just curious as to how this other wheel works compared to the damaged one?
Had the one been converted to electronic ignition?
[ame]
[/ame]
