Changing clutch on art positioner anyone figured out what torque to use?
Evening all, just about to change the clutch on my positioner but finding it difficult to read what torque you actually need.
Diagram reads:
3-4nm,26,5-35,4 IN-Lbs.
not exactly very clear! :confused1:
Has anyone else figired this out?
Cheers
Diagram reads:
Cheers
3 to 4 newton meters which in old language is 26.5 to 35.4 pounds per square inch
Close, its inch lbs.
If you haven't got the right torque wrench it's not a lot, probably 'barely nipped up with a t bar' would be more than you need.
Not helpful really, but 30in lbs is 2.5ft lbs.
