Yes definitely a walbro. No limiters on screws now. Doesn't mean there never was. Found settings fir what I think is the same carb on a rc boat forum so will try them later.
If I can't find any info I usually start 1 or 1.25 turns out on both and set the tickover up while keeping it running on the trigger then fine tune the L screw to stop any bogging
Do you do this with chain brake on or does it have to be off. Chees
I do it with the brake off so I can see when the clutch engages and starts the chain running.
Got the saw running pretty good now. Thanks all who helped. Ringed one ash log with it to tune the h screw and a few times the idol seemed high but then after a few seconds it drops again.
Just got to decide what to do with it now. I don't climb so don't need a topper. It probably owes me about £ 100 . Don't know what it's worth. But it will be sat in the workshop for now.
Thanks all
