what knots work best?
It would be good to know what type of knots work best and why in different situations. So in a few examples lets see what kind of knot one would use.
Setting up a pulley on a trunk before sectionning down?
Timber hicth its time consuming to set up and pain to keep moving it about specially after loading.
Running bowline its fast to set up easy, to untie even after loading but dont know why dont use it that much in this situation.
Cows hitch never use it, must admit cuase dont know how to tie it. I know that its used for this situation, any plus or minusses???
Lowering down a big section.
Half hitch and running bowline its my choice for the same reasons above.
Half hitch and timber hitch commonly used but time consuming i think.
Any others?
If need be to pull something with the truck? What knot would you use to attach the rope to the truck?
Double bowline perhaps for the same reason!
Its late and running out of ideas! Any other examples?
To secure a load of brush on the back of a trailor?
To send up to the climber something like a bottle of water or something with a smooth surface and no kink for the rope to hold on to.
What knot to join to ropes together for extra lenght.
To make a harness out of a rope?
Any other use that you can think and why?
Good night
Jack-arb
  • Replies 30
pluses: easier to pull tight then timber hitch.
minus: uses more rope, harder to open, can slip if pulled from wrong direction.
constrictor knot.
bowline on a blight.
timber hitch
blake loop
or attach a sling to pulling line with a klemheist and about 6 wraps.
overhand bend
water knot
sheet bend
clove hitch if i'm lowering a few small bits, i just rig em all one after the other.
alpine butterfly, i'd like to use this mid line, unlike a bowline it can be loaded from any angle.
i tie off my tail on my split tail with a overhand knot, fig 8s come out to easily, as its never loaded its not an issue
Jamie
