David Brown tachometer
simonm
1166 for 540 shaft
700 for 1000 shaft
So if your tickover is say 850,PTO will be 425 rpm on the 1000 shaft.
Plenty enough power for your new log saw - good for fuel economy but bad for the engine.
If you want to run a hydraulic log splitter at the same time use 540 for better oil flow.
I would never of worked that out :blushing: last time i ran a pto was on a big john deere and was all digital.
I see most saws run at 540, why is this 350? just geared differently?
Possibly the size of the saw, I noticed on my Balfor if I run at 540 the is a hint of speed wobble on the blade ,back off to 350 its bang on.
Ste
