Do any of you guys n gals know where I can buy a diamond tipped bench grinder to sharpen green teeth. Been on utube and have bought a variable speed drill on a tower with a bench grinder. I'm missing the vital component and I can't source it locally. Any suggestions?
Talk to Dean @ Bandit. The diamond wheel we use is made by 3M we have been using it for a good long time. I sharpen other guys grinder too. We burnt out a grinder at first. Buy the biggest grinder you can 3/4hp or above. 3/4 pillar drill too. You don't need water are the Tips will never get red hot don't dip them in water it makes them brittle, let them cool in the air. The diamond are best for green teeth. we have tried other wheels to sharpen. The 3m Diamond is not cheap, but it works and gives you a very sharp edge.
