550XP loose crank stuffer.
Mark_Skyland
I have just had a crankshaft bearing go ( one on oil pump side ) had just replaced piston a couple of weeks earlier , is the bearings failing a common fault , FR Jones says not.
Stuart .
These modern auto tune engines run a lean mix so bearing failure and seizure are never far away.
Run a richer mix and synthetic oil and hopefully it will help!
