Just had quick search in maintenance threads but couldn't find much. To change the mounts under the carburetor cover and the one at the front near on off switch, do you have to dismantle the internal handle carb parts to saws?
Or just unscrew and prize apart whilst quickly installing new part into position?
I'd it a nightmare job if you don't know how to put the trigger handle back together properly?
Any videos/links anywhere?
Thanks
It can be done easily enough without having to take the handle to bits. Just watch you don't put too much pressure on the fuel pipes and carb boot. Also they look similar but the A/V mounts are different.
What do you mean different? In the sense that what I think may be av mounts on saw may not be? Or that each of the three mounts look similar but have subtle differences so be careful when installing/selecting the mount?
Thanks for response mark
