MS 200T running problems - Again!!
Well,it' not quite as simple as that . The Walbro WT 326 is a fixed main jet carb whereas the two models of Zama are fully adjustable models .
Of the Zamas the C1Q-S16A is used on the 020T and the C1Q-s32 is used on the 200T .The main difference being the 200T carb has a compensater type head for use as the so called "intelecarb " .In other words the carb kind of self adjusts to conditions of flow of the main air filter . Either of these carbs will work .If you don't want the intelecarb thing to work just don't hook up the hose from the carb to the air filter box ,simple enough .
I got the saw running properly today, by cleaning the carb with carb cleaner. So i will see what happens next week. I will get my to phone STihl with the serial number and see what they say - if they won't change it i might replace it anyway, as it is a real PITA!
Thanks for all the advice, lads.
sounds like a new carb is needed. i had exactly the same happen it even worked fine some days and then other days it wouldnt work. took it to the dealer and new carb still under warrenty works fine everybodys happy.
