Does anyone know the differences between the 3200kg and 3400kg cabstars?
These are both single wheel models, I know the double wheel is 3500kg.
Looking at the 1999 - 2002 model.
Id like to know if the GVW could be increased from 3200kg to 3400kg, hence wanting to know any differences.
Thanks
I thought the lower was a flat bed and the higher a tipper?
Correct, although this one has been converted to tipper.
Just wondering if the chassis, axel brakes etc are the same, should be a simple test and up plate if so?
