The seal needs replacing around the glass. I looked on eBay and all the self adhesive flat rope for glass is 10 or 12mm. But the recess for the glass is only 5mm wide. Is there another option for sealing the glass in, or do I just leave half the tape hanging out the edge.
Thanks in advance
Sent from my iPad using Tapatalk
From memory its a flat rope, self adhesive on one side. Cut it to the correct width with a pair of scissors.
If your glass retaining studs have sheared off Villager do offer a door refrurb service during which all studs are replaced.
A
Thanks alycidon. I didn't know if cutting the rope would make it fray. The studs are ok. I was worried they wouldn't move without shearing off but they freed off. Thanks for your help
Sent from my iPhone using Tapatalk
Should be perfectly OK.
A
