73 that's going back a bit
is cladoptosis connected with summer branch drop?
would be interested if you've found any literature on hazard beams, apart from Lonsdale
customer has a big split in white pop limb, suggested taking some weight off above, she said leave it for now, been like that for years. Still in leaf above, went through gales like it etc, but the hazard beam doesn't inspire confidence visually.
In regards to summer branch drop - maybe. See the part about Ohio. The source cited by the book is however from 1902 (see here)!
Hazard beams, as long as they remain 'moist' are less of a risk (by-and-large, though not always). If the wood dries out, the friction that builds up due to a lack of lubrication means failure is more of a risk.
Hazard beams also depend on wood properties. Willow or horse chestnut - get them down, if the target area is bad. On oak, I have observed hazard beams in huge limbs that appear to have originated some time ago.
Of course, ain internal fracture is exactly that, and that's not 'good' (from a safety perspective). Obviously one must weigh up the pros and cons of leaving it / removing it.
I don't have a source for horse chestnut, though from speaking with a colleague he remarked that they a tendency to drop big limbs. I know in Lonsdale's book he used a HC in the example for hazard beams in one of the pictures.
I have seen a cracking (no pun) hazard beam in a willow and it has been there for years, however. It's flippin' wide, too. Considering the weight of the limb, I did laugh when, in a wind storm, another branch failed and not that one!
If you're interested, 'A Handbook of Hardwoods' has details regarding the wood properties of many trees. There is another edition for softwoods too, entitled 'A Handbook of Softwoods', though it's a lot smaller as it covers fewer species.
[ame=http://www.amazon.co.uk/gp/product/B00NQ6BN7E?keywords=a%20handbook%20of%20hardwoods&qid=1443868017&ref_=sr_1_12&sr=8-12]A Handbook of Hardwoods: Amazon.co.uk: HMSO: Books[/ame]
Edited by Kveldssanger
Links to past facts:
Fact 1 – A history of coppice woodlands
Fact 2 – Branch failures in wind storms
Fact 3 – What is bark?
Fact 4 – A history of man trying to afforest the Black Country, UK
Fact 5 – Mycorrhizae-facilitated communication between individuals
Fact 6 – Root severance and tree stability
Fact 7 – Development cycle of wood-decay fungi
Fact 7.5 – A brief history of Ancient Woodland in the UK
Fact 8 – Coal deposits of the past
Fact 8.5 – Europe's lack of tree diversity
Fact 8.75 – The resource demand of trees
Fact 9 – Endo- and ecto-mycorrhizal fungi
Fact 10 – An overview of cladoptosis
Fact 11 – Trees can help with human recovery
Fact 11.5 – Aborting fruit to improve tree vigour
Fact 12 – Vigour and vitality
Fact 13 – Photosynthesis
Fact 14 – How residents perceive trees
Fact 15 – Bid cherry-mediated competition between two of its principal herbivores
Fact 16 – Coppicing ability and suckering
Fact 17 – Concrete and asphalt as mulch?
Fact 18 – Root penetration of sewer pipes
Fact 19 – So exactly how small are micro-organisms?
Fact 19.5 – Bat-shaped soil amoebae
Fact 20 – Arbuscular mycorrhizae benefits
Fact 21 – What do plants need to grow?
Fact 22 – Utility installations and root pruning issues
Fact 23 – Seedlings and susceptibility to pathogens
Fact 24 – Bumblebees self-medicating!
Fact 25 – Doesn't exist because I cannot count above 24.
Fact 26 – Apical dominance
Fact 27 – Fertilisation – is it good or bad?
Fact 28 – The Black Poplar
Fact 29 – Sporophore (fungal bracket) formation
Fact 30 – Trees to regulate temperature
Fact 31 – Honey fungus sporulation
Fact 32 – Saproxylic insects
Fact 33 – A video on photosynthesis
Fact 34 – The pale tussock moth
Fact 35 - Białowieża National Park, Poland
Fact 36 – Reproductive growth in plants
Fact 37 – How plants detect light and the birth of pigments
Fact 38 – A more detailed look at light and photosynthesis
Fact 39 – Adaptive growth in response to mechanical stimuli
Fact 40 – Gravitropism / geotropism
Fact 41 – Telepathic plants
Fact 42 – Vernalisation
Fact 43 – Phenotypic variation as a means of compartmentalisation
Fact 44 – Responses by plants to herbivory
Fact 45 – Monoecious and dioicous trees
Fact 46 – Insects and flowers
Fact 47 – Trees and crime rates
Fact 48 – Branch shedding in more detail
Fact 49 – Factors that influence cladoptosis
Can a mod please edit my first post and permalink this post in the first post, so people can have easy access to this index? Cheers.
Turned out to be a busy day in the end - will get a fact done from The New Sylva tomorrow. So much text, I will have a hard time knowing where to look. I did spot a cool fact on oak breeding programmes, which I may write about.
5/10/15. Fact #50.
The effects of elevated ground-level ozone, CO2, and other gaseous compounds within the atmosphere are well-documented on the whole.
Perhaps a more obscure factoid regarding elevated ground-level ozone and CO2 is that of
elevated levels, but still levels that may occur naturally (and more readily as pollution continues), disrupting the 'communication' (chemical) between plants and insects.
For instance, elevated levels of CO2 (not ambient levels) adversely impacted upon plant communication (and subsequent recruitment) with carnivorous insects that predate upon herbivorous insects defoliating the plant. Elevated ground-level ozone, similarly, disrupted communication of plants with wasps, by rapidly oxidising chemical secretions (volatiles) by the plant before they could be adequately 'received' by the wasp.
Perhaps research into such changing atmospheric conditions should therefore more readily consider the impacts on plant volatile emissions, as we move into a more polluted future.
Sources:
Karban, R. (2015) Plant Sensing & Communication. USA: University of Chicago Press.
Pinto, D., Nerg, A., & Holopainen, J. (2007) The role of ozone-reactive compounds, terpenes, and green leaf volatiles (GLVs), in the orientation of Cotesia plutellae. Journal of Chemical Ecology. 33 (12). p2218-2228.
Vuorinen, T., Nerg, A., Ibrahim, M., Reddy, G., & Holopainen, J. (2004) Emission of Plutella xylostella-induced compounds from cabbages grown at elevated CO2 and orientation behavior of the natural enemies. Plant Physiology. 135 (4). p1984-1992.
5/10/15. Fact #51.
Locally-sourced hawthorn seed has shown, through a number of field trials, to flush later, be thornier, more resistant to mildew, and more vigorous on upland sites than seed sourced from the Continent - to the point that landowners, where new hedges are being created, should source from local specimens. This will help ensure the hawthorn remainds very hardy and prosperous, going forward.
The practice of local seed-sourcing also is highly important for associated wildlife. The approprite phenology and flowering habits of hawthorns, as well as their thorny character, provide insects and birds with viable habitat respectively.
Source: Hemery, G & Simblet, S. (2015). The New Sylva: A Disource of Forest & Orchard Trees for the Twinty-First Century. Spain: Bloomsbury.
6/10/15. Fact #52.
An earth-shattering fact for today. Didn't realise this myself...!
The plural of Sorbus is (at least for the English language) Sorbi. I am unsure whether in has any basis in general nomenclature, however.
Source: Watson, B. (2006) Trees - Their Use, Management, Cltivation, and Biology. India: Crowood Press.
