Might be hoping here but I've got a pair of type C Arbortec breathflex in lime green in a regular leg and I could do with the short leg in the same waist size. They are absolutely BRAND NEW, I have never worked a day in them. A previous employer of mine in New Zealand very kindly bought them for me as a leaving present, so I can't return them for a different size as I'm now back in the UK.
Guest Robin@Arbortec
If they are in brand new condition I might be able to arrange to have them swapped. Call on 01553 768 346 - the main Arbortec Office number - and ask for Robin. If they are in good nick there should be no problem.
You still have your location as New Zealand. Someone could cut them down and hem the bottoms for you without too much trouble if the swap doesn't go through.
Hi ROBIN did see you at show robin there a good lot a arbortec thanks Jon
