Be a good idea to be a bit more specific, do you have a tractor to power it or do you want one with an engine attached that is maybe road towable.
25t a year, thats a fair heap, around 45 cube, I assume its going into a boiler so you will need the capability to cut long logs.
Do you have a limit on the area you are prepared to travel to to see/collect said unit.
Caledonian Forestry have a JAPA 700, thats a nice little machine, will cut to around 500mm long, need a 35 hp or so tractor to move and power it. Something like a MF135 or Dexta.
Unless your timber is billeted then its now a bit late to be processing logs for the forthcoming winter unless you have old cord with bark falling off.
A
Hi
Yes I have a tractor which is big enough. Currently I have a Balfor PTO saw and a towable log splitter but its too slow and I dont want to spend all my time as there is too much double handling of the logs.
Ideally a cut length of about 450-500mm long. Caledonian are closed so I will contact them at the end of July when they reopen.
This years is all done, Im planning now for next year
Basically I will consider anything PTO or engine driven
