may be better just tickling them up with a angal grinder, dont get them too hot tho,
Problem is they have warn so much there is about a 1" gap between them.
Had the same exact problem. I used some gas cutters in the end. Just heated them up very slightly then they undo easy. Get a bucket of water ready to put old bolts in. Also leave a gap between using the gas to let the rotor cool. It won't take long once you get going. Tried a blowtorch before the gas cutters no joy not hot enough. Good luck. Worth doing it will chip like new.
